gregcope
hi all
Our boat has 240v sockets that are only on when on shore power. We need more USB charge ports. Ergo I am going to swap some of the sockets for those with USB ports.
I also have an idea of wiring in a parallel USB 5v regulator powered off the 12V supply so that the USB ports can be powered up when on the boat supply.
Does anyone see an issue with this? When shore powered the socket regulator will power up the (switched) 12v-5v regulator, but if switched off this should be fine. Any ideas what happens if left switched on?
