vas
Cardo this ram is scrap!
I'm afraid you have to fork out for a new setup
V.
V.
Yes, there is a bracket just above the water line. Even I would've picked up on the issue of there were only one bracket!Ok, I assume there are lower brackets for the rudders too?
Interesting. I hadn't thought about doing it this way. However, how would I attach the ram to the rudder in such a way that it'll accommodate the movement of the rudder as it turns?Probably the simplest solution at the moment would be to keep the ram mounted on the transom (the environment really isn't a problem with the correct materials - exterior rams are used all over the place on ships, with no problems), but actually mounted to the transom on one end, the other end attached to one rudder and a bar connecting the two rudders. This is not the most elegant solution, but it is easy, quick to install and about five hundred times more suitable for the job...
Whilst I'm slowly learning this stuff, I feel nowhere near comfortable enough carrying this work out myself. I'd still need to find someone to do the work for me. But who should I approach here in France? :/ A standard boatyard?All the above is easily available off the shelf and a simple job to fit.
Tell me about it!Your crazy wire rope system is really most odd!!
Thanks. I feel I'm going to need it!Good luck!![]()
Sorry, I don't know what this means?Edit: make sure you get a BALANCED double acting ram
Some of you may be aware our Southerly 105 was modified by the previous owner from a single transom hung rudder to twin transom hung rudders. Whilst doing this, he also changed the steering system from cable to hydraulic.
When we bought the boat, the surveyor had a look at the system and seemed happy with it as it was working. Unfortunately, having owned the boat for a year and a half we have discovered various problems with the modification, with differing levels of seriousness.
Our latest issue is pretty serious, I believe.
QUOTE]
Generally Hydraulic cylinders are not so much custom made but a selecion of standard catalogue componects assembled to give the customer
the configuration required.
Your cylinder is probably easily serviced by someone who recognises the components used. Check your Yellow pages forsuitable companies like this.
http://www.hydraulicpower.co.uk/home.html
You could also google Images in google using the search Hydraulic cylinders. This will give you a selection of pictures from the web and might
indicate possible suppliers.
I am not sure what you mean regarding the securing of the cylingder with wire!!! Usually the fixed end is attached with a trunnion and pin or ball joint.
Bilge, have you not looked at the pictures...?
Tell me about it!
http://www.foreandaftmarine.com/1-HC53223.htm
Above is the ram used on my boat. This is a specific marine ram built by Hynautic, and is the sort of thing I mean. Price is a bit steep, you could get a non marine specific version cheaper.
I was going to reassure you that rebuilding a hydraulic ram is not a major problem.
The one on my boat is of unknown make, but a local (to me) hydraulic shop rebuilt is using a mix of spares off the shelf and bespoke seals. The ram cylinder was reamed out. Total cost was about 80 GBP.
However, your pictures tell a different story.
Of most concern is that there appears to be no provision at all for an emergency tiller.
I would go along with others who suggest a re-think of the whole set-up.
Did the original configuration have a link through the tramsom?
Good luck!
