Portsmouth (uk) Inner Swashway Local Knowledge
Channel Sailor
5 Mar 2009
Portsmouth (UK)
I am fairly new to Portsmouth harbour and have already used the Inner Swashway a few times when the tide is above 2m rise. if I want to arrive from a direction from somewhere between SW to SSW I was wondering if any locals can advise me of the deepest water route (and at what depth CD they reckon it is)? Also 1) any useful transits to take a reliable depth track, both entering and leaving 2) Bearing in mind recent channel dredging, how wide is the channel either side of BC Outer post (E.g before you could run aground on the north end of Hamilton Bank)? My yacht draws 1.55m.
My chart shows a least depth of 0.5m cd quite close WSW of BC Outer Post that marks the entrance. So it could be the answer will be 0.5m.
DJE
21 Jun 2004
Fareham
www.casl.uk.com
You could probably be do a better than 3 hours with that draft. With the previous boat that drew 1.2m we almost never went the long way round. Now we draw 1.7m and go round the outside about 30% of the time. 0.5m at CD is still about right and the old back-bearing of 030 degrees from the Round Tower still seems to work. On the way out it's easy just read the tide gauge off Fort Blockhouse add half a metre and that's the depth in the swashway. Then decide what you need to allow for weather conditions and wash from ships and pilot launches and make your choice. On the way in pass close to the race mark just east of Gilkicker and read the echo sounder there. Whatever depth you have near that buoy you will have about 0.6m less water at the NE end of the swashway.
1 Aug 2018
we also have 1.2m and use it more than the 3 hour rule. i tend to assume the worst and treat it as having zero water at CD but DJE is right; 0.5 is more like it. I'll push it if the weather is calm but with a weather eye on swell and or barometer impact on tide heights. As to the best route - there is a leading line on the admiralty charts but i just pass close to he racing bouy and try not to hit the wall
XDC
17 Mar 2018
I was going to say exactly that. I just treat the whole area as zero water at CD and allow for rise of tide and sea conditions. Only ever had one anxious moment where suddenly a line of boats left the harbour seemingly together.
I edged over towards Hamilton Bank and thought I was going to hit. A bit white knuckle but that's the only time in many years.
capnsensible
15 Mar 2007
Atlantic
Its been a while but I used to sail out of Pompey a lot but not since dredging so the pilotage tips I used may well have changed.
The first was on the seaward corner of HMS Dolphin. There was some sheet piling with concrete on top. If sea level was on or above the metal, the Inner Swashway was plenty deep enough for a Sadler 34.
For a transit coming in or a back transit departing, there are (were) two distinct building features. One was a pointy blue cupola type roof. This could be lined up with the right hand edge of a square brick tank? on another roof. Sounds complicated but in reality easily seen and worked for the Inner Swash outside normal convention!
My favourite place to sail out of in the UK.
Pinnacle
6 Jan 2006
Wot he said. (y)
Aardee
22 Jan 2004
Portsmouth
We sail out of Portsmouth on a Granada 34 (1.8m draft) and also use the metal piling by HMS Dolphin as a makeshift tide gauge.
andyp
22 Oct 2009
Gosport
Similar to @capnsensible and @Aardee with their makeshift tide gauge at the harbour entrance, when approaching the Inner Swashway from the Gillkicker end, I use the sewage outflow pipe support structure by Fort Monckton to know if there is enough water for my 1.6m draft.
Of course, lockdown has gone on for so long I can’t remember exactly which bit of the structure I use!!
Sadly, when they moved the Gilkicker light out to a post they did not consider adding a tide gauge to it.
dom
17 Dec 2003
They are; he was saying to use the Swashway if there wasn’t enough water for the inner one.
Yup, I have to regularly use all three routes.
Racing yachts are often caught in the Swashway navigating under the mistaken belief that Wightryder I & II are deeper than they are. They draw just 1.6m, same as the OP!
Giblets
5 Mar 2006
Surrey
You wouldn't happen to be thinking of the seaward corner of Fort Blockhouse by any chance (underneath the NCI lookout)?
There is a tide gauge on BC4, the first red pile just inside the entrance.
lw395
16 May 2007
The inner swashway ad the whole area to the West of the Hamilton Bank basically does not dry.
But bits of it are 'kin shallow at LWS.
There are some lumps near Fort Monckton which are close to drying at a very low tide. Opinions differ as to their exact location and what they are.
The locals race Victory Class boats without much bother at LW, but they only draw about 2ft and are fairly unperturbed at rattling over the alleged lumps at Monckton.
Don't push your luck if the sea isn't flat, AFAIK, the bottom is very hard and the chop can be steep. Basically it's Gosport and you don't want to land there anyway.
capnsensible
15 Mar 2007
Atlantic
Sounds like the spot but its an awful lot of tides since I sailed outa Haslar and headed South!
Goldie
29 Sep 2001
Nr Falmouth, Cornwall.
Like others, I used the steel pilings under the NCI lookout as my tide gauge outbound (If there was about 18” visible, I was fine). Inbound from the West, there were some wooden groins on the beach and (from memory) the 3rd or 4th groin had an old outfall pipe. My rule of thumb was based on whether or not the end of outfall pipe as submerged. That boat drew 1.8m .
CAVEAT: I haven’t sailed into or out of Portsmouth for a few years and certainly not since the major dredging works. If you’re going to use this, please check the visual references for yourself.
dom
17 Dec 2003
I mean, this steel piling malarkey sounds very clever and all that. But isn't the handy datum-based tidal gauge with nice clear numbers painted onto an easy-to-read red and white marked pole so much easier and safer? :)
It is also conveniently placed right at the edge of the small boat channel!
DJE
21 Jun 2004
Fareham
www.casl.uk.com
Some peoples' minds work differently. If conditions are a bit borderline I will always read the gauge or check the depth at the race mark whereas Sue will just look at the water against the shore and say something like "too much beach showing" - and annoyingly she's usually right. But that comes after hundreds of trips in and out of harbour.
