Portishead Lock Closures
AllanW
14 Jan 2010
Gloucestershire\Boat\Colvic Watson 25.6\Cardiff
Just in case you have not seen it.
8th - 22nd October 2012 - Lock Shutdown
We are planning to undertake our annual lock shutdown for essential maintenance commencing on Monday 8th October 2012 with the lock programmed to come back online no later than Monday 22nd October 2012. We will endeavour to complete the works as quickly as possible and should this be the case then we may be able to re-open on Friday 19th. We will keep you posted!
As a berth holder, if you would like to continue using your boat throughout the duration of the shutdown then Penarth will be more than happy to accommodate you. Please contact Penarth on 02920 705021 to book.
http://www.quaycrm.co.uk/demodocs/Portishead E-Quay 13 09 2012.html
Thanks for the reminder.Couple of years ago I arrived outside Portishead at HW unaware it was closed for maintenance until I called up for a lock in.(Im sure there were plenty of notices sent out so not blaming anyone bar myself)
Spent the night dried out in Pill on an empty yacht club mooring .I enjoyed going somewhere different as previously had only ever glanced into the Pill as passing by going up to Bristol.
Good Luck with the maintenance work, hope it all goes smoothly.
