CliveF
Ok so its a 22lt Nuovarade "hulk" Polyprop tank, In a T32 Honwave
4 years old never been a problem until i went to fill up this time.
The clear window over the gauge was in place but not attached.
As i picked it up after filling to put in the car petrol flooded everywhere.
Back at the temporary residence I managed to find enough things to investigate. ID of the thread in the tank was 34mm ish ( some irregularity )
The OD of the bung was only 34.14 ish so virtually NO thread engagement.
I tried PTFE tape , which failed, I suspect i did not put enough thickness on.
Next I managed to get a fairy good engagement on put a ratchet strap round it and drove some slips of wood under to jam it in place. that lasted for the two short trips i did.
Now back home I want to make a Proper repair but what with.
I am inclined towards the RTV 2 stroke crank case gasket sealer I have which is setting type but not sure if OK for constant fuel contact ( fuel does slosh up into the clear bung.)
Or build up a much thicker layer of PTFE tape to see if that will give a better grip.
Hylomar blue I have , it is fuel proof but non setting so no mechanical grip to hold in place.
Loctite 577 also fuel proof but £15 for 50ml is nearly a new fuel tank ( that may have the same problem.
Permatex also non setting so no mechanical grip.
Epoxy glue is not fully fuel proof.
Gorilla glue is NOT recommended for fuel contact
Does anyone have have any reliable suggestions that THEY have actually used for how I might fix this problem, that I have yet to consider.
Nothing I would trust has appeared on YT.
Thanks in advance
CRF
Thanks in advance
CRF
