janeK
Subject: Australian bricklayer report
This is a bricklayer's accident report, which was printed in the newsletter
of the Australian equivalent of the Workers' Compensation board.
Dear Sir,
I am writing in response to your request for additionalinformation in Block
3 of the accident report form. I put "poor planning" as the cause of my
accident. You asked for a fuller explanation and I trust the following
details will be sufficient.
I am a bricklayer by trade. On the day of the accident, I was working alone
on the roof of a new six-story building. When I completed my work, I found
that I had some bricks left over which, when weighed later were found to be
slightly in excess of 500lbs. Rather than carry the bricks down by hand I
decided to lower them in a barrel by using a pulley, which was attached to
the side of the building on the sixth floor. Securing the rope at ground
level, I went up to the roof, swung the barrel out and loaded the bricks
into it. Then I went down and untied the rope, holding it tightly to ensure
a slow descent of the bricks.
You will note in Block 11 of the accident report form that I weigh 135lbs.
Due to my surprise at being jerked off the ground so suddenly, I lost my
presence of mind and forgot to let go of the rope. Needless to say, I
proceeded at a rapid rate up the side of the building. In the vicinity of
the third floor, I met the barrel, which was now proceeding downward at an
equally impressive speed. This explained the fractured skull, minor
abrasions and the broken collar bone, as listed in section 3 of the accident
report form. Slowed only slightly, I continued my rapid ascent, not stopping
until the fingers of my right hand were two knuckles deep into the pulley.
Fortunately by this time I had regained my presence of mind and was able to
hold tightly to the rope, in spite of beginning to experience pain. At
approximately the same time, however, the barrel of bricks hit the ground
and the bottom fell out of the barrel.
Now devoid of the weight of the bricks, that barrel weighed approximately
50 lbs. I refer you again to my weight. As you can imagine, I began a rapid
descent, down the side of the building. In the vicinity of the third floor,
I met the barrel coming up. This accounts for the two fractured ankles,
broken tooth and several lacerations of my legs and lower body.
Here my luck began to change slightly. The encounter with the barrel seemed
to slow me enough to lessen my injuries when I fell into the pile of bricks
and fortunately only three vertebrae were cracked. I am sorry to report,
however, as I lay there on the pile of bricks, in pain, unable to move, I
again lost my composure and presence of mind and let go of the rope and I
lay there watching the empty barrel begin its journey back down onto me.
This explains the two broken legs.
I hope this answers your inquiry.
<hr width=100% size=1>JaneK
Dear Sir,
