Thanks Stemar - a very useful link. I learnt a lot from this article on the yachtsurvey.com site...about osmosis & blistering
I am still much more worried about never having had anodes...........
jaylo264
Our 1966 Westerly 22 weighed almost the same on lifting out of the caledonian canal last autumn ( just under 2 tonnes, said crane operator) as she did on going in there 4 years previously.
If the boat weighs 2 tons, say 4000 lbs, close on half of that is iron in the keels, and at least another quarter is timber, anchors, fittings, rig, tanks, etc. There is probably much less than 1,000 lbs actual GRP. Even totally saturated, 1000 lbs of GRP laminate will only absorb 2-3% water, so 20-30 lbs. You can't diagnose water content of a hull with a crane - far too imprecise.
Quite so (although I have seen laminate with far more than 3% water by weight) but you can't tell with a water meter either. All you can do is check above and below the waterline and compare the two figures you record. I would find it far more significant that many of these old boats have no blistering evident at all while some relatively modern boats are poxed to hell. The difference can only be quality of care in the original layup. Someone will be bound to say the old Westerlys are three times thicker in places, but that's not an issue when looking at surface blisters. My point originally was that these old boats are polyester. It's still the resin of choice for most and this is not the cause of blistering, it's quality and care in manufacture.
So how can a blisterless hull have osmosis?
Any clues?
I have told this story before but..
I have a survey for my boat dating back to the late 80's it warns that the WC bowl shows:
"early signs of osmotic blistering"
I have not been too worried as it is ceramic.
I dont believe that is correct Mike. BY their very chemical structure, polyester molecules are prone to breakdown in the presence of water which is why boatbuilders have moved on to vinyl resins and even epoxy. So a hull can deteriorate just through being wet, but it is a slow process unless there are laminating faults.
There used to be an article on the SP resins site about this but as with most British companies they have been sold out to a foreign multinational and I can't find it any longer.
".......By the way, don't assume that using any combination of resin and re-inforcement used in 1969 or any other time means it can't happen. It can. It's just not as prevalent as surveys would suggest."
BoatMike, and everybody else,
This thread ought to be posted complete in YM as an example of basic information that every yottie ought to be aware of. All we now need to know are the moisture reading numbers so that we can be surveyors of our own hulls/topsides/everything FRP as well .....
How can I print it out in one fell swoop ?????
Cheers,
N
