alahol2
While I'm stuck in the house, I have a meguiars G220 V2 DA polisher which has bitten the dust. I suspect the variable speed electronics module has died.
I know very little about how this thing works electrically... I am looking at any way to get it going again.
The 240V lead (2 wire) comes into a switch. From the switch 2 wires go to the speed module. (There is a 0.3uF capacitor across the 2 leads, presumably for radiation suppression.) From the speed module 2 wires disappear into the body of the machine, presumably to the brushes etc.
Can I just bypass the speed module ie take the output from the switch and connect to the wires leading into the motor? Would that run it at full speed? Maybe I can use an external speed controller such as... https://www.ebay.co.uk/itm/2000W-SCR-Dimmer-240V-AC-Voltage-Regulator-Heater-1000W-25A-Fan-Speed-Control/292181746872?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Or will I blow the whole thing up and/or electrocute myself?
PS spares are not available.
