vas
morning all,
since i disassembled the 2.5 heads in MiToS, I'm there with no running water as there was a single plastic/whatever type off white jobbie pipe bringing the water along the craft teeing off (with bronze bolt on equip, with compression rings) wherever there is a supply. Now, having 3 cut out tees is no good for water... Further, I often spend 3-4hours in the morning and have to go to my office nearby stinking which is no good
so I need to address that soon. Yes, I know I can wash my hands in the sea 1m away but depending on the tide it gets slippery and may end up swimming instead of cleaning
Anyway, planning to repipe the lot (heads moved from stbrd to port anyway so different setup alltogether) and was wondering what is the normal practice nowadays. I mean in domestic plumbing we (at least down here) have a collector off which the pipework comes out. That means that you can individually block supply to sink, shower, washbasin etc. Should I do that or go with the one_pipe_fits_all_and_if_you_have_a_problem_you're_buggered approach of yesteryear?
As you can imagine I'm for the collector approach coming to a second Q regarding ID pipes, usually it's thicker to the collector and thick(ish) for the shower, all else being 15mm I'd have thought.
Opinions?
cheers
V.
Opinions?
cheers
V.
