ghostlymoron
I think that for tiller steered yachts, under the spray hood is ideal. Preferably demountable with a seperate power supply so that it can be used below for the tedious business of entering waypoints at leisure.
I'm not sure about this "tedious business of entering waypoints". I used to use waypoints when I first had a GPS, but with a plotter, why do you need waypoints?
I was concerned about how weatherproof the area under the sprayhood was
I spent a lot of time on a boat with a large plotter in the cockpit and an identical one below. The chart table one was rarely used.
I haven't had a plotter for a few years - the last was a Lowrance 5M I think. Entering the names seemed to involve a lot of scrolling through the alphabet with the accompanying bleeps. I've now just got a handheld Garmin GPS (non-plotter). I still find waypoints handy to avoid hitting stuff which you may not notice on the chart. Most navigators I know still use them.Agreed - entering waypoints is quick and easy, if ghostlymoron finds it tedious, he's doing it wrongly!
My first radar/plotter was installed in 2000 and was not submersible. I have got used to working my way, so the replacement was put at the same site.Modern plotters are generally fully submersible.
Some older ones are only IPx6, which means proof against powerful water jets from a half-inch nozzle from any angle.
I really don't think the odd bit of rain or spray finding its way under the hood is likely to be a problem.
I use waypoints very little. I suspect they're mostly a hangover from older GPSes.
I don't need to look at a chart when I am helming, so the basic information of DTW, BTW, SOG and COG are all I want. I can display XTE on a separate instrument if I need to, and the rest of the arithmetic I can do in my head.
Don't you use a "route" when you're going somewhere?
No. What for?
(Note that this is not the same thing as setting off with no plan)
Cockpit.
No, not trying to say anything about good or bad practice just reality. The chart table plotter may have been used for occasional passage planning but day to day use the cockpit one was used. This was probably 95% of the time and that was the case whatever skipper or crew was on.But is that because the very handy plotter in the cockpit encouraged "bad" navigational practice? If so, what?
Both
