dje67
Plastic water tank on a Bene 36cc - the boss for the inspection hatch has separated slightly from the top of the tank causing water to leak when the tank is full. The crack is at the 3 o’clock position on the photos attached below the threaded boss.
I’m looking for repair suggestions…. I could just try to fill the joint area with, say, CT1, or cut off and re-seat the whole boss. If I do the latter, any suggestions for adhesive, noting the there is some flex on the tank top.
I’m not keen to apply any sealant to the inside of the tank as this might contaminate my drinking water.
