Pithy log entries
A little thread drift for amusement. From aircraft tech logs (P) pilot report (S) solution by engineers
P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft.
P: Something loose in cockpit. S: Something tightened in cockpit.
P: Dead bugs on windshield. S: Live bugs on back-order
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent. S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear. S: Evidence removed.
P: DME volume unbelievably loud. S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick. S: That's what they're for.
P: IFF inoperative. S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield. S: Suspect you're right.
P: Number 3 engine missing S: After brief search, engine found on right wing.
P: Aircraft handles funny. S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums. S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit. S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from midget.
