Portofino
Badly internally ( not really visible externally) corroded elbow .The spray ring holes are partially blocked and when stopped the sea water drips through back from new cracks + holes from the corrosion into the exhaust side of the turbo and through an open E valve , kinda siphons itself to fill the open cylinders .
@ Bruce It can’ t be leaky CAC unless theses are raw water cooled ? Says it’s salty and the close coolant levels have not changed .
Won’t be any backwards running either as after a back run the then progresses to Fwds would hydro lock it and bend a rod .
Aside I doubt the injection pump would run it backwards anyhow .
Another could be huge stern wash ( on the Rhone - barges etc ) temporarily altering the relative levels of the water in the horn / riser and turbo …..the open E valve senario .
He might not have been in the boat when this happened.Moored up etc .
