Pine tree down
Wansworth
8 May 2003
SPAIN,Galicia
Just along the hedgerow thank fully a good way from the house a Pine tree has fallen…..agood 2foot diameter by 60 foot straight as a die…….strange as not been windy at all.Would make a great mainmast for a lugger of gaffer.Will take picture as not sure of type…….Unfortunately in Galicia,although I have handy a main and foresail of a gaffschooner ,as you do😏
Fallen Pine……what type of Pine is it?
Photos 3, 4and 5 make me think, European Larch possibly? Branch, Cones and Needle form look similar to the Larches here in my haunts...:giggle:
. . . Would make a great mainmast for a lugger of gaffer.Will take picture as not sure of type…….Unfortunately in Galicia,although I have handy a main and foresail of a gaffschooner ,as you do😏
A schooner rig isn't going to work on a Dufour 24 - the mainmast will be in the way.
A gaff yawl, though, with a decently assertive bowsprit, could be the way to way to go. 😁
Assertive bowsprits cost money in marinas!
Ah but you then get the type that can be steeved up (is that the proper term?) vertically out of the way when you have to be in a marina, in similar fashion to the Heard 35 -
Heard 35 archive details - Yachtsnet Ltd. online UK yacht brokers - yacht brokerage and boat sales
Or reef it in horizontally, like on the Heard 28?
Heard 28 GRP hulled gaff cutter archive details - Yachtsnet Ltd. UK yacht brokers - yacht brokerage and boat sales
I have a catalogue somewhere for the Dufour 24 - I shall try to find it, and scan it, and post a copy for you.
I had a telescopic Bowsprit on my steel Gaff Cutter. Made of box section steel, the inboard section was 4 inch square while the outer length was smaller. At sea the outer would be extended and secured with a 12mm through bolt. In a Marina my boat became over a Metre shorter.. :giggle:
Ah but you then get the type that can be steeved up (is that the proper term?) vertically out of the way when you have to be in a marina, in similar fashion to the Heard 28 -
That would be great,thanks
And all those sporty modern boats with retractable bowsprits for asymmetrics / code 0s think they're so modern! Sounds like you were well ahead of them.
It wasn't on the original sail plan, but after the first Med voyage and all that light airs or occasional breezes I realised a light outer Jib would be of value, and so it proved to be.
Later, I also rigged a Cruising Chute with the Tack run out to the Bowsprit end for crossing to the Caribbean, and again that extra length of 'Sprit worked really well.(y)
:) That photo is from the days of Photobucket I think it was called, and quite a few of my photos ended up of that size. As a complete Tech numpty I never knew why... If I try to enlarge them they get so blurred that I don't bother trying..
The sea, yep! running down the Trade Wind so not unusual.
