Pillow mould
MM5AHO
1 Oct 2007
Central Scotland
In the autumn, when I take my boat out of the water, I take various things home for either dry storage or maintenance. One issue I've never cracked is pillow mould. During the year most pillows on board get a bit dirty or a bit mouldy. Some can be washed, but they seem to loose shape and texture and become a bit useless after that. Sometimes drying and sunshine bleaces it out, sometimes, only replacement is the answer. Has anyone a great idea on stopping this waste? Is there a special pillow? Or a technique to prevent mould?
How wet is your boat inside????
Ive taken to putting all the bedding in bin bags, closing all the hatches completely and running a dehumidifier about 8 hrs a day- works very well but probably cheaper to buy new pillows!
Pillows do need to be washed now and then but to preserve the fabrics in the saloon and keep the air fresh I have found that sealing up all the ventilators and using the Kontrol de-humidifier crystals works for me.
The boat is fairly dry, and only white pillows have this problem. It maybe doesn't help that humans touch pillows a lot, and sweat etc must feed the mould? I store them in bin bags when not in use aboard, and at home in winter.
I gave up using a pillow - I became convinced it's better for your back to do without! certainly solves the OP's problem.
