Brentwales
Here are the pictures of my keel and keel bolts.
Having noticed water leaking from the rear of the keel yesterday when cleaning the inside out today I went back to investigate further. You can see under one of the bolts there is a void. I thought the water maybe leaking from there as water was pooling under it, but doesn't seem to be that.
I decided to start taking some of the antifoul off around the keel join to inspect and that appears all sound with no leaks or visible cracks and there is no movement in the keel.
I found a crack at the rear of the keel and when I pressed on it hard, some water came out. So I dug out the crack which you can see in one of the images. It's about two inches long and is a hairline crack extending from the rear of the keel. I checked all the bolts and noticed the bolt directly above where this leak is wasn't tight at all, so I've tightened that up.
How should I deal with this?
https://ibb.co/M6Xq1jH
https://ibb.co/PDLSTqs
https://ibb.co/NKnMq2X
