capnsensible
This is the wire end of a headsail halyard. It decided to relax some 650 miles short of St. Lucia. Once alongside, it took the most Excellent Rodney Bay Rigger around 8 minutes and not a lot of money to repair with two swages for safety.
But about an hour with our youngest crew dangling at the top of the mast to re thread it!
Full marks though to Selden furling mainsails. We kept up our 6 knot average under main only and proved that with care, such a sail can easily and safely rolled in and out on a broad reach. :encouragement:
Mid following Caribbean sea with lots of it trying to visit us in the cockpit..... which swamps the engine control panel and gives a permanent beep. Engine running, bilge slowly fills. Check Keel Bolts!!!! then hull valves, then engine exhaust. Yup, right on the through hull, the bend in the pipe as installed finally splits.
Solution. Stop donk. Stuff outlet from over transom with plastic bags. Cut back pipe. Easy especially when you have a 19 year old crew to stuff into the transom space. Remove old bit from through hull. Difficult. Fit hose back on. Recover bags and crew. Restart donk. Solved. Remarkably during the hour or so the diagnosis and repair took, we were still going in exactly the right direction.
Flat batteries as in expired. No pictures, they look the same.
Alternator bracket broken, sorry no pics of the most excellent Mindelo welder repair.
Dont you love boats!
