bluerm166
The attached shows a survey along our prop shaft - apparently a 25mm metric dia. The end of the exg. worn brass / nitrile bearing ,not yet drawn out,shows 38.2 o/d,so presumably imperial. Replacement is considered because of the noticeable play that allows the shaft to be lifted manually .I can see that I can find a 25 metric x imperial o/d bearing .
There appears to be wear on the shaft at the cutlass position that would give quite a starting tolerance for a new 25mm bearing.The shaft is apparently running true.
There is some marked wear at the position of the stuffing box gland ,but it is not scored and can be adjusted to a drip.
What is the opinion please of the starting tolerance, varying between 0.34 mm and 0.1 mm plus the tolerance on the nitrile ,bearing in mind the nuisance involved in changing the bearing ? The existing bearing has lasted 5 years.
