Permanent live cigarette socket
single
19 May 2012
Cardiff Bay
I want to add a cigarette socket which is permanent live. Obviously a fuse in line but what size and do I need some anti-surge gadget or anything?
Fuses and cables should be sized to match each other and the maximum load or maximum amps the socket can take (not more than the socket is sized for)
If you fit a 15 amp fuse in the supply to the socket anything you plug in with lighter rated cable should also have a fuse to protect that cable as close as possible to the plug, preferably incorporated into it.
The ordinary cigarette lighter sockets are pretty poor as there is no positive retention of the plug. Poor connections and even over heating if large currents are drawn are possible consequences.
it would be advisable to find plugs and sockets that lock positively together.
Only low power load stuff like phone charger,laptop,camera etc. Only one at a time.
For those sort of things, surely it doesn't need to be permanently live?
My car lighter socket is fused at 5A, I have fitted about four round the boat which come off existing 5A circuit's and one that is switched and fused at 10A. They all go through the battery isolation switch.
Motion activated cameras don't work without permanent live.
To me, 'permanently live' suggests straight off the battery, before any isolation switch.
This camera won't be plugged in all the time, as you also want to charge other things.
When you are on the boat, I take it that you don't turn off your domestic battery, so unless you put a dedicated switch in the 12v socket, as I have in one of mine, the socket will be live when you plug something into it.
I take it you don't want it live when you leave the boat?
