Perkins injection pump spares
38mess
9 Apr 2019
All over the shop
Would anyone know where I could get spares for this pump please? It's leaking and I believe the O rings have hardened.
rogerthebodger
3 Nov 2001
Thanks. I want the copper washers as well. I have a huge supply of O rings but non fit.
So have I thats why I take a sample to my local seal supplier
Again most injector repair firms will have injection copper washers.
When I had my injectors refurbished the company supplied copper washers included in the price.
Parts4Engines also sell them
Don't know where you are located so cannot find anywhere local
Rappey
13 Dec 2019
A few years back calcutt marine had an article suggestion it would be wise to have a cav injector pump rebuilt on the older units as they have rubber seals which modern bio in diesel attacks which can lead to leakages into the crankcase. The rubber would be replaced by nitrile.
No idea if yours is of that type.
Bilgediver
6 Jun 2001
Scotland
O-rings can be obtained for any seal or bearing supplier
Just take a sample
or try Parts4engines
Perkins Perama M30 parts
These are standard fuel pumps so can usually be obtained also from a diesel injection service agent or even Amazon'
I usually find that washers can be annealed and reused. Something we frequently had to do when I was at sea.
Heat till cherry red and plunge into water.
Amazon.co.uk : copper washers
38mess
9 Apr 2019
All over the shop
All done. In the end I just replaced the O rings on the injector pump body. One had definitely failed and the rest were hard. Simple job, hardest part was taking the injector pipes off.
