Perkins 6354 - Fuel Consumption?
Well they certainly looked clean without oil leaks. Should get a closer look at them and some more info this week. Thanks.
Are you thinking of purchasing vessel??
Dot 4 was a big big improvement over earlier versions of 6.354, previous vesions which were Dot 2 I think, Ben will correct me here I am sure. Perkins started with real good base motor and corrected the earlier exhaust manifold set up. Marinisation was neat with large combined manifold/heat exchanger set up 'Manicooler'. Used a water cooled turbocharger for the first time.
For some reason majority of Dot 4's went for export to the US, mainly used in trawler yachts in the early 80's and early on had real good reputation.
Perkins dropped the Dot 4 or Range 4 engines as they were known when Perkins Sabre was created. This was the start of some major issues. Manicooler was manufactured by Serck, with creation of Perkins Sabre and end of the Dot4 Perkins was asked to purchase the tooling for the Manicooler which Perkins declined. Manicooler is prone to internal corrosion and failure, when Perkins stock ran out they went back to Serck to source new units for service.........In the intervening period ownership of Serck had changed hands and the original patterns were scrapped off in rationalisation.
Created big problems in the US where heat exchanger failure resulted in need to re-power.
Not sure of the politics but it appears Serck were prevaled upon to manufacture fresh tooling, dunno who paid however this cost had to be freshly amortised. Word is that a new Manicooler is over $4,000. MESA (Marine Exhaust Systems Alabama) and Orca manufactured replacements but even they are not cheap.
If you are purchasing vessel with Dot 4's suggest you obtain paid help from somebody who KNOWS the engines to do survey and obtain up to date price and availability of manifold/heat exchanger and build this into your offer.
Begs the question, why was rear main oil seal arrangement redesigned on the Dot4. 'To eliminate rear main oil seal leaks at high installation angles found in marine applications'. Their words not mine...........
can only comment on my own set up.
100%realiable
no water or oil leaks(but they have had a full recon,just before i got the boat).
for 40 year old engines...start first time everytime.
so i just love'm..:D
100%realiable
same, no heat, turn the key almost instant, never fail to start, having said that they do smoke when cold, fine when up to normal running.
The exception to the above, is after a long period of no running I pull both stops then crank them until I see oil pressure on the gauges, then push the stops in and start.
