peteK
It may be that your preheater is stuck on and thats what is causing ignition switch to get hot.
Certainly not electricallyNot this old chestnut again? Perhaps the diesel fuel in the OP's engine is never ignited?
Richard
Glow plugs and starter motor are both electrical and are needed for ignition of the diesel to commence on many engines.Certainly not electrically
other than perhaps fuel supply or cut off a diesel does not require any voltage ?to run once started thereby negating the complications of an ignition system
Where are you?Now I'm in big trouble, the wiring loom/harness is no longer available from Perkins ☹ (part number 4172P002)
So I'll have to get a replacement made, would an auto electrician be suitable for this kind of job or are there loom/harness specialists?
But not all is the point ?Glow plugs and starter motor are both electrical and are needed for ignition of the diesel to commence on many engines.
Richard
Self explanatory??And the point of post #3 was?
Richard
Where are you?
12 volts supply Switch off. Negative
| ____________ \___________{ Load }_______________|
|________ 12 volt________|
12 volts supply Switch on. Negative
|__________________________{ Load }________________|
|_______ 0 volt__________ |
Sorry to labour a point but you said in a previous post you saw voltage between terminals 1 and 2 with the switch off. See the above diagrams. It is perfectly feasible to see 12 volts with the switch off.
With the key in the off position, that is what I would expect, see diagram 1. That test only proves continuity or a break in the circuit i.e the switch is the break in the circuit, therefore the switch is working correctlyThanks for everyones replies -its been very useful, I was back to the boat today so have some direction this time.
Boat is in Lanesborough Co Longford and I'm a hour and a half drive away.
With better concentration this time, I tested the connections again and found the following;
With the ignition key off, I had 12.7v between terminal 1 & 5. When I remove the relay (SRB500) the voltage drops to zero, so either a faulty relay or faulty pre-heater but since I don't need the pre-heater I can just disconnect it and leave it. I've ordered a replacement ignition so will fit that when it arrives. I have inspected the starter and alternators connections for any signs of scorching/burns and none found so I think thats the cause of the short circuit found and resolved.
Moving on, I have some wires behind the dash that are scorched and others have the outer insulation melted and need replacing, I reckon if I can source the cable and connectors then its just a matter of careful rewiring which I happy to undertake (and have the yard mechanic look it over when finished)
Some questions;
1) I believe these connectors are not made anymore, so what is the modern equivalent?
2) I need to replace about 9 different coloured wires behind the dash where they are scorched/melted and I see a huge selection on www.autosparks.co.uk but I'm unsure of what size wire I need. I've measured the existing wires with a calipers and have a variety of diameters 2.3mm, 2.7mm, 3.3mm & 4mm -- would anyone know the sizes that I need for this panel?
I will also need a selection of spade connectors in various sizes because I don't think they are all standard.
Final question, where I have a short piece of wire thats damaged, is it ok to replace that short piece with new cable by using butt connectors? I'm proposing this for the smaller sized wires not the 3.3mm & 4mm which will be replaced in full length.
Thanks for reading if you got this far...![]()
I notice from the image of the panel that the key switch has only 4 position legend. The legend is applicable to the 4 plate switch truth table, not the 5 plate.Thanks for everyones replies -its been very useful, I was back to the boat today so have some direction this time.
Some questions;
... Why 2 battery warning lights?
Have just been reviewing the whole thread.
Worrying that you say the insulation is melted on cables with an OD of 6mm. That size cable is capable for about 60-70 amps!
From what we are given, you have more problems than just the switch, that you have proved is in fact breaking the circuit.
I would recommend you employ a competent electrician sooner rather than later.
With the size of cables and the current you are playing with can rapidly lead to a very burning experience.
It’s a similar panel as my 4236 panel and I have twin alternators: house bank and engine start.
