jabber
This is a shout for assistance and the sanity of my father....stuck in Spain.
Perkins 4108 marinised
All was well on crossing across then during a run from harbour the engine gave nasty clanging sounds and was stopped.
Investigation followed and it was found 3 out of 4 vib mounts loose.....possibly cause of noise. All injectors removed, engine cranks freely. Injectors replaced and whilst trying to bleed on starter motor the engine labours very slowly, draws high current....enough to melt leads!. Batteries ...new and full charged. Injector pump and injectors overhauled and ok. Only issue is crank has a reasonable amount of play i.e clearance to flywheel is on the large side. Again no issues when injectors removed. Finally starter motor returned to UK, fully checked with no problems.
Any ideas?
Any ideas?
