Perkins 4108 anodes
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
My present boat has a Perkins 4108, like the previous one.
The previous engine had no anodes, as some 4108 were fitted with anodes: where do I look for in the new engine to check if it has them ?
The previous owner could not tell..
thanks
Roberto
20 Jul 2001
Lorient/Paris
Mine is fresh water cooled, with heat exchanger.
AFAIK, many engines were originally electrically insulated from the sea (in theory, cooling sea water offered a path for current anyway): negative return to battery, etc so they were not fitted with anodes; but there were other engines which were supposed to be grounded and accordingly were fitted with anodes, for ex at the heat exchanger.
I looked at my engine and there are a few bolt heads here and there that could be those hiding an anode, but before unscrewing anything I wanted to be sure.
My version of the manual does not say anything about anodes..
silverseal
26 Jun 2003
Solent City, Hampshire,UK
I have had several 4107/8 engined boats, none have had anodes, and my manuals does not mention them.
My current one has an additional anode along side the rope cutter on the propellor shaft, and a copper earthing strand between the two.
Hope that helps
sailorman
21 May 2003
Here or thertemp ashore
Do u Have a TMP gearbox.
if so u should change the existing raw water inlet / out-let
nipples that the cooling pipes are attached to ( the originals were brass / gun-metal ) these r now made in zinc as the raw water cooling fitted by Duffields have a mixture of copper pipes + Alloy gearbox housings. this equates to a battery i had to have a gearbox rebuild @ £1100.00. /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
<font color="red"> i still have a set of spare zinc anodes if anybody wants them @ a reasonable price as i have re-engined & there not now required </font> /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
