Perkins 4107 info please
Can anyone please advise me of the oil capacity of the Perkins 4107 now I have finally removed the oil filter casing having removed hydraulic winch pump, solenoid, various cables etc etc.
Also, water pump, an ATT Jabsco 4900 is beginning to through out water from the drive pulley end (!!!) and I am summising it is on its last legs. Do I need to replace like with like, can you still obtain service kits for this pump or could I replace it with a nice shiny (cheap) new pump, bearing in mind clearance between this pump and the alternator is about 3mm max.
Thanks.
Rob
Sammy
26 Jun 2001
Engine capacity should be 7pints according to my literature.
The pump sopunds like it just needs a new seal which is easily replaceable see other reply, Cheaper than a new pump.
