superheat6k
Indeed, see I struggled to keep it simple.Why not just use a vacuum gauge?, that will tell you if there's a restriction.
I expect EDC/EVC would give you an error code for low fuel pressure if that was the problemWhy not just use a vacuum gauge?, that will tell you if there's a restriction.
Is there anything that indicates how or why it snapped?
So... update on this old thread for those who may be interested...
Volvo engineer took the boat out. About 30meters off it's berth, the boat lost all drive on the port-side. Transpired that the port-side shaft snapped just after the P-Bracket and the propellor flew off.
Marina wouldn't let an amateur diver retrieve the propeller, insisted on a 5 man dive team at great expense.
Propeller retrieved. Boat lifted. Shafts removed. Port-side prop damaged starboard prop as it made its exit.
Both shafts pulled. New shaft and check/refurb of other. Both props refinished and balanced.
Many weeks later, boat ready for sea-trial.
Worst part - insurance refusing to pay up. I put forward that I must have had an underwater collision with a submerged object - they "opine" wear and tear and shaft failure. Nothing showed up on my pre-purchase survey in February. ££££££+
The joys of boating!
