boatmike
My helm position is a loooong way from the engines. One has two Yanmar-supplied extension sections added to the loom, the other one. Oddly enough it's the one with one extension that gives the most trouble
Thought so. Th'rs yer problem m'dear!
The exact spec of relay is not critical but if you fit one slightly oversize it would not harm. ASAP sell one and have it in stock no 714852. It is 40 amp (plenty enough as it will only take the signal current to the solenoid not the starter motor current) and is a 4 terminal SRB601 type so simple to wire. About £15. You might get one cheaper from an autofactor or Maplins but this will do the jobbie OK.
A relay of this type will actuate with low voltage OK on the signal side as it is only closing light contacts on the supply. Fit as short a cable as you can from the battery to the power side. The starter motor main terminal would do fine. Any other info you need PM me any time.
