Andy92
Hi all, I’m new to the forum and to forums in general so apologies for mistakes and if posted in the wrong place, I posted it here because the boat is kept at Barry island.
I know it’s been covered but just looking for advice with regard my exact scenario and weather it would seem pointless to carry on with my current approach.
I’ve recently purchased a new to me westerly centaur with an aged Penta MD2B which starts first turn of the key and seems to be a good engine over all. Unfortunately however I recently ran it for an extended period of time for the first time after changing the impeller and thermostat (as a precaution) and the cylinders are overheating can’t even touch them they got so hot.
There’s a good flow of water out the exhaust however I presume the coolant passages round the engine were so blocked no water was going round the block.
I’ve Taken the exhaust manifold off and poked about with coat hanger wire, then directly injected bicarbonate and vinegar (gentle approach), then holts speed flush from Halfords, then oxilic acid and let it sit overnight. I injected this with a syringe straight into the ports on the side of the block after removing the exhaust manifold . The result is the rear cylinder now runs cool as it should, but the forward one still runs hot.
I have been advised to try brick cleaner which is a bit stronger and intend to do this as the next step. Failing that is there anything else I can do without removing the head ?
If it comes to having to remove the head I would be looking for a mechanic to do it for me I think as I am not too confident about that step and also in a rush to get the boat in the water.
Any help is much appreciated.
Sorry for the essay I struggle to be concise
May be embarrassing if I have posted this in the wrong place
Cheers, Andy
Cheers, Andy
