Penguin - two large holes in stern
FourSheets
31 Oct 2020
Hi-
recently got a penguin, it has two large rectangular cutouts in the stern. I was told it was for flaps rigged with shock cord to allow for drainage. Does anyone have some familiarity with these? I’m thinking some plywood glassed-over with some gasket around the edges? Any advice appreciated.
I am also just thinking about glassing them over and calling it a day.
Thanks!
wombat88
1 Oct 2014
Transom flaps were/are often clear acrylic and hinged near the rudder pintles. They would be drilled to take a shock cord that would hold them closed under most conditions. After a capsize, once you get moving again, the water runs to the stern and has sufficient pressure to push the flaps open and escape. Well that's the theory anyway.
They should be high enough to be clear of the water, I'd be tempted to re-instate if the boat feels quite original. Up to you otherwise.
SaltIre
13 Mar 2017
None of your nosey business
I know little about Penguin dinghies, but an online search shows none with transom flaps - so closing/sealing the apertures seems a reasonable thing to do. They are a standard fit on many other dinghies.
Might it not be easier to get some hinges and ply or perspex and make new flaps? Unless you do a very good repair it might look odd.
You can get perspex in that well known chandler - B&Q!
Fantasie 19
23 Mar 2009
Chichester, West Sussex
Not your boat but this will give you the idea..
index.php
jwilson
22 Jul 2006
Transom flaps really only work if you can get the dinghy onto the plane on a reach when near full of water after capsize, in which case they can work spectacularly well. At low speeds they do nothing. I doubt a Penguin is fast enough to make them work properly, which may be why other boats of the class don't have them. The other time they are useful is if bringing the boat ashore up a slipway you have a lot of water in the hull, they will empty most of it in seconds rather than slowly through a drain bung hole.
FourSheets
31 Oct 2020
Huh- wierd. I wonder why they were put in. I’m thinking of doing the rubber flap/ shock cord this year and maybe filling them in next year if it doesn’t work.
wombat88
1 Oct 2014
Ask on the CVRDA (Classic and Vintage Racing Dinghy Association Facebook page or forum. Someone will be familiar with Penguins.
Facebook Groups
Dinghy Database Index
Although it doesn't get a mention that I can see in the index...but 'lost classes' are much appreciated!
oldbloke
24 Jun 2018
Inevitably there's more than one Penguin dinghy. Google mostly shows the American "international" penguin, which would be unlikely to benefit from transom flaps. But there is a South African Penguin which I think has trapeze and spinnaker which would certainly make transom flaps work.
Toestrap webbing works well as a hinge.Or a single piece of the flexible clear plastic (polycarbonate) fixed in the midline and held with thin elastic can work as a self tending flap as long as the transom is mostly out of the water
wombat88
1 Oct 2014
Mine were hinged with what looked like small white plastic piano hinge...but then the boat was built by Jack Chippendale...
TernVI
8 Jul 2020
Mine were 1.5mm or so polycarbonate sheet.
You don't have to get the dinghy going that fast for them to work, just move you weight back and sail the boat out from under the water. It works on most dinghies like Enterprise, Scorpion, Kestrel etc
No use at all if you should manage to fill the boat with water in lighter winds though!
They only need to seal well enough to get the boat launched, the transom should never be in the water. Having clear plastic flaps allows you to see that you are not dragging the transom.
An alternative is to use clear self-adhesive plastic film. If you are unlucky enough to capsize you just tear them off, being careful not to litter the lake or sea of course! People like this option as the boat will stay dry when launching on a pond with steep slipway. It's also least weight in the end of the boat.
michael_w
8 Oct 2005
Utter nonsense IMHO. Transom flaps worked well both on my Enterprise and Merlin-Rocket. A dinghy ain't never going to plane when full of water ....
