Peformance Rudder profile and Shape
savageseadog
19 Jun 2005
I know there are accepted optimum aerofoil sections for rudders which covers the streamline section, but what about the shape in elevation? I've seen all kinds of tapers, thick, raked aft, thin, curved etc. Is there an optimum profile?
Birdseye
9 Mar 2003
s e wales
Do you mean sideways on? If so there are two criteria. Balance is an issue relating to the pivot point and how heavy the boat is on the helm. That apart, rudders are just another foil like a keel so its an issue of chord against overall length.
adwuk
10 Jun 2015
Tarbert
Most effective when the leading edge is at right angles to the flow. Everything else is tradeoffs between foil efficiency, strength, stock position and balance. The taper is there counter the increased lever that the generated force has on the stock. The challenge comes from wanting 1) a low drag efficient foil operating in clear flow and 2) the turning force generated at the waterline. Now design around those conflicting requirements.
bignick
10 Aug 2011
Poole
Small section nose radius combined with a rectangular planform can also lead to abrupt and sudden stall.
Keen_Ed
13 Dec 2002
start here:
http://www.ericwsponberg.com/wp-content/uploads/keel-and-rudder-design.pdf
"Tapering a planform to match the characteristics of one half an ellipse produces optimum lift distribution and the least vortex drag"
Then I would look at things like TP52 rudders, Merlin Rocket rudders etc and go and ask a naval architect.
IANANA, but I would think that it depends also a lot on the boat. Plus planforms with a straight bottom are easier to build and more resistant to damage than pointed tips. Higher aspect foils are easier to stall and give less feel than lower aspect.
