Gin
You may remember from an earlier post that I wanted to test gps charting on a PDA before going the whole hog on a serious upgrade of my boat system.
I bought a Fujitsu-Siemens Loox N520 with integral GPS and now I've loaded Map-Tech OS and marine charts to test it out (I couldn't get on with the Seaclear method of scanning and cropping/stitching).
The Map-Tech manual tells me what to do with Garmin/Magellan units but for others tells me to select NMEA 0183, a Baud rate of 4800, which I have done, and the software should be able to receive the GPS signals- it doesn't!
I am leaving the GPS locator running in the background, checking evry now and then to make sure it still has a signal but all I get on the chart page is 'Communication timeout' and this is what the manual troubleshooter says
"Communication timeout
The software was not able to receive any data from the GPS and has given up. It will try to re-establish communication in a few seconds. If this persists, see "No data" above".
Nothing happens however long I wait.
I reckon this is operator error but for the life of me I cannot improve the situation. Any ideas guys/gals??
Be warned to those helpful souls who answer, there is another question lurking about loading up extra charts on an SD card, and being able to find them on the 'Programs' list but this should be simple and I shall work on that before having to admit, as Arnie does "I'll be back"
