Plevier
No problem. I would use an HL11 6pin dip opto schmitt, either leaving the led input floating for differential use, or not, as the case may be.
The output is inverted and being a schmitt trigger design has fast rise and fall times. It operates from 3 to 15v, the led current is 50ma max so a 470r or 1k series resistor would be fine for a 12v signal and a diode across the led input will protect against any negative voltages.
Ian
I don't think that's going to work.
ST60 NMEA OUT ON = A 11V, B 0V = current in inverting opto = output LOW
ST60 NMEA OUT OFF = A 11V, B 11V = no current in inverting opto = output HIGH
