pC onboard again
whipper_snapper
9 Aug 2006
Kenya
I have been hesitating about a PC to run MaxSea and email via SSB. I have decided I do NOT want a laptop (including the asus eeee!) and was planning to build a mini-itx. But I just came across this which looks very interesting. It runs on 12V, very low power and small size.
http://www.fit-pc.co.uk/index.html
I would use win XP and wondered what people thought about the specs. Is it up to running MaxSea ?
Specs:
CPU: AMD Geode LX800 500MHz
Chipset: AMD CS5536
Display: Integrated Geode LX display controller up to 1920x1440
Memory:
NEW! Larger 512MB DDR 333MHz soldered on-board
Hard disk: 2.5” IDE 60GB
NEW! Built in 802.11b/g WiFi
Ports: RJ45 Ethernet ports 100Mbps
3 x USB 2.0 HiSpeed 480Mbps
mini RS-232 (cable available)
VGA DB15
Stereo line-out audio (headphones)
Stereo line-in audio / Mic
Dimensions
Width: 100mm
Length: 110mm
Height: 30mm
Weight: 380g
Software
General Software Embedded BIOS
Special BIOS features:
Etherboot for boot over LAN
Etherlink for BIOS update over LAN
Linux: Ubuntu 8.04 (preloaded)
Gentoo 2008.0 (preloaded as an option)
Other Linux distributions are tested to work
Windows: Windows XP Home SP3 (preloaded as an option)
Mechanical and environmental
Splash and dust resistance enclosure
Material: Black Anodized Aluminum body with PC/ABS panels
Operating temperature: 0 - 45oC
Power: 12V single supply
Power consumption: 4-6W
At 500MHz, it will probably work ok, but you might think twice about using the term "run" - maybe "walk" would be more appropriate. /forums/images/graemlins/ooo.gif
Actually, the 512MB of RAM might be as big a performance issue - I don't know how much the current version of Maxsea uses memory - I have quite an old version (that I don't really use too much anymore...)
Plus, there is still scope for some kind of small incompatibility that stops it all together...
For me, a laptop is pretty well optimal.
- compact and low power
- built-in UPS
- can quickly pack it up and tuck it away safely
- easily and quickly replaced if (when) it goes wrong
I'm not too convinced by the current trend for solid-state/flash drives. In my experience, laptop hard disks are extremely reliable...
email over ssb is painfully slow - at 3 kbps is less than half of one percent of my pretty sluggish broadband.
with both a lappy and ssb on board I found it better to use internet cafes or mobile phones. downloading my emails on the latter only cost a few pence per day. plus it was reliable which hf/ssb isnt.
I have one of these digital yacht PC"]http://www.mesltd.co.uk/digital-yacht-cf50-p-747.html]PC[/url][/url] . Expensive compared to a laptop but the this was an upgrade for an existing PC so screen already built in. Works well. Runs off 12v. Bought a wireless aerial for surfing free wireless when available
TudorSailor
I'd get a laptop, with external keyboard/mouse/monitor - you can put the laptop away with closed lid and continue to work on it whilst onboard, then take it ashore to go the cafe etc etc when possible.
