vyv_cox
To be fair, your 2011 link is the original article from Paul Stevens, the surveyor who first alerted us to the problem. A lot has happened since then and it may be understandable that he was not absolutely correct in his words.I've looked at a few articles on this now and I can see that Tranona is correct. There is quite a widespread and long-term misunderstanding on the meaning of of the Recreational Craft Directive. Effectively, as Tranona says, the RCD only specifies a minimum life. It follows logically that various kinds of seacocks will both meet and exceed this.
However, a logical fallacy chain seems to have taken root that goes something like this.
1. The RCD specifies that seacocks have to last for five years. [True]
2. This is a very limited standard. [Not true - it misses out the notion of minimum.]
3. Because builders will be following this poor standard then it is important to change seacocks every five years [Untrue it assumes a minimum standard has become a maximum one.]
The article seems to take a further step apparently supported by 'quotes' from some 'experts'.
4. Since seacocks have to be changed every five years and DZR is a seacock then DZR must be changed every five years. [Untrue.]
Here's a 2011 Yachting Monthly report in which the first three mis-steps are made.
https://trip.ayy.fi/wordpress/wp-content/uploads/2014/08/Seacocks.pdf
Although there seems to be widespread confusion there are some reliable interpretations. The RYA look completely sound on this, for example.
The international standard specified in the Recreational Craft Directive for metallic sea-cocks and other through-hull fittings is ISO 9093-1:1998.
This requires sea-cocks and other through-hull fittings to be made of a material that does not display any defect within five years of service that would impair its watertight integrity.
This does not mean that components need only have a service life of five years but rather that components must function for at least five years without displaying any defect.
As far as the RYA is aware, since this standard was introduced in the late 1990s there has been no evidence of widespread failures of sea-cocks and through-hull fittings that met this standard.
