KellysEye
I would look a the chart( and write down the headings then add the tide table for the area, that was for short and long distance passages. we also carried the pilot books for every area.
No, it is a really, really good thing!It's probably not a bad thing for any skipper to sit down and consult the relevant sources 'from scratch' when devising a passage plan rather than rely on someone else's homework.
In my experience every passage is unique, a sweeping statement as my late father would say.However are there reliable sources from which the most common passage plans for yachts could be obtained??
I blame SOLASI never knew that sailing was so complicated.
It's not! Where are we going, what's the weather doing, what's the tide doing. Recorded it and that can be in your head. "Be Prepared" as the Scout Motto says to stand up in front of the Coroners Court/MAIB investigator and demonstrate that you did some planning. Having a bit of paper is far more evidential.I never knew that sailing was so complicated.
Well obviously one can cheat by going somewhere without tides![]()
The Os been getting a bit of flack I reckon yet I've found local advice really good and can see a demand for a repository. Stuff like "leave Caernarfon xx hours after LW to get through the Swellies" or "Leave Pwllheli xx hours after HW to get through Bardsey". Obviously not replacing a passage plan but gets you started in the right area
...I think making your own plan is an important process, you need to check over the source material yourself, so you know why you are leaving at horrid AM and the effects of being early or late etc. I wouldn't want to use someone else's plan, or expect anyone to want to use mine.
I also want enough source materials on board to make a new plan, any new plan which might be wanted...
