Slocumotion
Just finished a job for which the "Dremel" was, not just the best, but seemingly the only tool which would "cut it" : - the lead-out grooves (222 of them) for the 37, 16mm diameter deadeyes for a scratch-built model yacht. Mine (the tool that is) is the 2019 cordless version, and I've had plenty of time to consider the making of jigs, accessories etc that would make it more generally useful, now that I'm into small scale stuff like this model, but it seems to me that the endfloat is going to be it's limitation. Mine has 2mm - no real problem when using burrs, wire brushes, grinding stones etc (the kind of stuff I've been using up to now) but my set of accessories includes a tiny plunge router bit, 2.5mm diameter x 3mm deep - I don't see that working at all well, however accurate and rigid a mini router table I might make. So I'm wondering if there is any point in taking it apart to see if I can improve matters at all. Is that in fact excessive for one of these things, or are they all like that from new? Would a real Dremel be the thing to invest in?
