Panasonic Toughbook CF-08 connection problems !
"Talk to" in the sense of transfer files from one to the other without using a USB stick?
You could connect both to a wifi hub and browse one from the other, or perhaps use an ethernet crossover cable between the two if you don't have a hub. It depends upon what you are trying to achieve.
Richard
..Then you want to set up remote desktop between the two devices. AS they're on the same network, it should be straightforward... WIndows has a built in capability certainly from XP on... It may be called Remote Assistance in earlier versions.
