wotayottie
Thanks all. Your collective suggestions have helped formulate a plan. No idea how easy/or not getting the old coating off may prove though where the coating has cracked I can pick it off with my finger nail as it seems to have very little grip on the base metal. Have not tackled it yet as still using the boat until last weekend and trying to keep it intact. Most of the damage has not ruptured so not exposed the under surface. Will now plan etch primer and suitable topcoat though when the weather gods will allow this is anyones guess. Thanks again folks, Terry.
Aluminium is a bitch to get paint to stick to - a little pinhole or chip and the corrosion travels under the paint, swelling and lifting it off. You get the same issue with motorbikes as with boats so you arent alone. I would not admit it to Jeannneau but personally I would have thought 5 years use without any paint lifting at all would be pretty good.
Touching up will not last but it may well be easier to do that regularly than remove and strip the pedestals. If you feel up to removing and dismantling then the easiest way of repaining would be to take them to a plastic coater ( most big towns have one) and he will blast them clean and put a plastic coat on them. To give you a guide to cost, a pal is just having this done for the frame and tinware of an old Jap bike ( got to be more work that 2 pedestals) and the cost is just £90.
Any colour you want. You could even have them done in some Harley type metalflake. Pink say.
