Trundlebug
I did Avocet outdoors with Epifanes 2-pack. I wouldn't be in a hurry to repeat the experience! First of all, (unless things have come on in the last few years) I don't think there are ANY mask filters that are suitable. Some are better than others, but I don't think any of them are regarded as "safe":
http://www.hse.gov.uk/mvr/bodyshop/isocyanates.htm
That said, these guys claim that they've not had any complaints...
http://www.ebay.co.uk/itm/Gerson-2K...Mask-NOT-AIR-FED-MASK-CAR-PAINT-/350690393436
I waited for a hot, dry and almost windless day in summer, and tried to get the paint on just before noon. Inevitably, a variety of bugs landed on the job. Best thing is NOT to try to pick them off. Leave them until the paint hardens and then you only have to polish their footprints out, rather than their whole bodies and / or the big finger mark you left while trying to pick them off! I tried a polythene tent round the boat but because it was over grass and foliage, the humidity inside the tent just shot up.
I used a small HVLP gun but wished I had a larger one because the "fan" from it was pretty small. I'd have got a better finish with bigger gun but I don't think the compressor I was using would have provided enough air to feed one.
I painted one side and was absolutely delighted by the lovely gloos, so I then went round to the other side and when I'd finished that, to my horror, I went back round the first side and saw that it had more runs than a test match special! Sick as the proverbial parrot, I could do nothing but wait for the runs to develop on the second side (which they did). I was surprised at how long after the paint went on that the runs appeared. I also discovered (once it had hardened) just how hard 2k paints are to sand! Eventually, I got the runs out and then (a week or so later) had another go, but this time I was so scared of getting more runs that I think I probably put it on too dry and too fast. These "mist coats" that everyone talks about seem to have eluded me. Several very thin coats, "dusted on", built up into something with a rather disappointing gloss.
It's not "awful", but it's certainly not as good as a professional job. Probably "only just" better than with a paint brush. It is, however, as hard as nails. This season, we've been on a mooring with a galvanised steel ring on top and in light airs, the boat just rubs slightly against the steel ring. I thought it had damaged the paint, but a quick rub with some buffing compound and all the marks disappeared.
Yep, my experience mirrors yours.
I resprayed a car once, when doing a full restoration (admittedly with cellulose not 2 pack).
I found that I had just started to get the hang of it as I was finishing the job...
My conclusion was that although it's certainly possible and many people have done it with great results, for me it takes quite a bit of practice to "get your hand in" and get the technique right. By the time I've got it right, the job's finished.
Whereas if I'd let a pro do it he is spraying all day every day so he will make a much better job of it.
I'd never try and put anyone off doing it themselves though, as I've seen some great results achieved by people who have never sprayed before.
And the small areas I have managed to spray well give enormous satisfaction.
It's just that the large areas I didn't manage to spray well required repeated sanding, rubbing back , respraying etc etc which give enormous frustration! Always in corners and creases which aren't easy to get to...
