Paint it blue
My two bobs worth
Hi build epoxy primer first
And then two pack in the sane colour as the hi build primer
Because . For a bit more work you get a better looking finish that ensures and as Stemar quite rightly points out, white scratches in blue are awful!
Sml Jotun is pretty ok to use and inexpensive
Another thought from the depths of my memory.
On another forum, a good while ago, they were discussing professional v DIY painting of topsides.
Professional will look better
Yes, from a metre away if the amateur uses a good roll and tip technique. 10 metres if he does a sloppy job, but only for the first year or two. After that, wear and tear will even things out. After 5 or six years, the amateur job will look better than the pro because the amateur can afford to do a repaint. The guy who went pro will be having palpitations over how much the cost of a repaint has gone up.
