robbieg
In common with ,I suspect, many others my boat has a stainless steel P Bracket. Its not bonded to my main anode system & is isolated from the prop shaft anode by the rubber cutlass bearing. I've only recently bought the boat but historically the P Brackett has been antifouled. Looking round the boatyard this seems to be pretty common ie antifouled P Brackets. However someone I know whose buying a similar boat has been told that the P bracket should have the antifoul taken off to prevent corrosion.
2 questions:
1. How do others protect their P Brackets?
2. Why does removing antifoul help with reducing corrosion?
Thanks.
2 questions:
Thanks.
