P-Bracket corrosion
ste7ve
26 Apr 2004
I have a Nauticat with a bronze p-bracket for supporting the prop shaft. When new the p-bracket was, I believe, coated in gelcoat which even covered up the bolt heads securing it to the hull.
Over the years (about 11) the gelcoat has come away and exposed bare metal. Normally I paint it all over with a couple of coats of underwater metal primer and then apply normal antifoul over the top.
Every year at lift out I find that most of the antifoul and primer has disappeared and I am back to some bare metal again. Some of the metal looks a bit pinkish which I believe is not a good sign because it indicates electrolysis action. The boat has 2 big anodes close by on the hull and also a shaft anode.
I was thinking of re-doing the whole bracket with some gelcoat or epoxy material before doing the usual antifouling.
Any advice on this whole matter?
Sounds like it's not been grounded. You say there are two large anodes nearby but don't say if the P bracket is connected to them, have you tried mutimeter to see if continuity? Shaft anode won't protect it as the cutless bearing is effectively an insulator with the nitrile bearing.
A bronze bracket should not suffer corrosion.
Pink colouration is usually a sign of dezincification but its brass that suffers from dezincification ... bronze does not contain zinc. Its an alloy of copper and tin. Never heard of de-tinification !
If the pink colour is only surface deep it not something to worry about.
look at Vyv Cox's website. Info there on dezicification and IIRC on P brackets
http://coxengineering.sharepoint.com/Pages/default.aspx
Hi Steve. I have an NC43 and the wire that supposedly is connected to the P bracket i found didnt in fact do so anymore: it had corroded, I checked with a multimeter. I found the nuts on the p bracket bolts (under the aft cabin floor in mine) and put a new bit of grounding wire between it and the main anode. I also drilled through the p bracket and fitted a disc anode to each side of it. This seemed to stop the "blowing off" of the paint caused by electrolysis. I have to say I that I have being doing a lot of work to rewire the boat to improve the electrical systems which I believe are exacerbating the electrolysis
Best wishes piers
My P-bracket is almost certainly made in manganese bronze, which of course is actually a modified brass, definitely subject to dezincification. I have been epoxying it for protection, but like the OP have had problems with adhesion of primer to the bronze.
Last season I painted my prop, a Bruntons so probably not a manganese bronze, with Hammerite non-ferrous primer followed by some Italian antifouling. Adhesion between the A/F and the primer was not great but the primer has stuck very well. This year I will try the primer on the P-bracket. It is usually the case that epoxy does not adhere well to non-epoxy primer, so I shall probably use the Italian A/F on it.
Here's the prop after a season afloat, before pressure washing.
Thanks for all the comments.
I will certainly check the electrical side. If my memory serves me well the p-bracket is not grounded and maybe they relied on the thing not being exposed to the seawater being covered in epoxy.
I was intrigued vyv using Hammerite underwater on a boat. I assume that is the red paint showing thru on the prop.
If I do use some new 'flowcoat' epoxy to cover the bracket is it best to primer the metal first or can it go straight on?
Yes, the red is Hammerite non-ferrous primer. It seems to be a fairly effective antifouling.
Your epoxy will almost certainly not adhere without a primer, but there are epoxy versions. I suggest you need to roughen the metal quite vigorously before applying it. Adhesion of paint to brass and bronze is quite tricky.
