Oyster lightwave 395
blush2
26 Dec 2008
Are you thinking of 'Blush'? she may have been re-named, but was a LW395 hull moulding with a different one off deck, plus a bendy fractional rig. I looked at her in 2000/1 when she was for sail in Ipswich, but swmbo thought the multiple runners were a bit ott.
Blush is still Blush, we did do the double handed series and kept her on the Hamble until recently. We have owned her for 18 years.
We had the rig modified with swept back spreaders which allowed the removal of the checkstays to make her easy for the two of us to sail. The plan was to go long distance and we spent a year including the Canaries and Azores. The runners have not proved too much of a problem, my other half single hands her from time to time.
The core is okay. However, I would suggest checking all the deck fittings, especially those added by previous owners to make sure the balsa was sealed where holes have been drilled.
Can't comment on the interior, Blush was a stripped out racer until we got her, we added all the creature comforts.
Lightwave395
14 Aug 2016
Me in Cowes, the boat back in UK now at St Mawes
Thank you! About the surfing part, in which wind/sea/lake conditions/sailchoice are we talking about? Further: I was hoping due to the lighter weight, it would mean it really performs in light winds. The boat in question has the shoe shape in the keel. I think our range is between 5 and 20 knots (family on board)
Is it an easy boat to sail,? And what cruising speeds in 10 to 20 knots of wind are to be expected? And do you think its more a long distance boat or do you prefer it in smaller sail areas as well?
Whilst Amandla Kulu was quick in light airs she did have a very full race sail wardrobe which filled the living area during races- Light and heavy No1's downwards and latterly both Symmetrical and Asymmetrical kites, having also sailed on 'Expedite' (which I think later became Pip Hare's 'The Shed') I'd say the most comfortable wind speed range is probably 8 - 20 knots although I don't know whether you plan to have a furling headsail. When I raced on my boat I had hanked headsails and at the top end 30 knots of breeze called for a No3 headsail and one reef. They do have strong simple rigs, I had the puckering experience of gybing Kulu off Yarmouth one Cowes week during a 48 knot gust and the rig stayed in the boat (which was more than a couple of crew nearly didn't)
In fairness I'd probably say that IMHO if you want a boat to meander around on with the family it might not be the best choice but if you don't mind a bit of effort it will reward you with rapid progress. I am enjoying cruising but don't particularly want to do it slowly
This is the blog of a 395 currently racing in the ARC 2-handed. May be of interest
Rainmaker
Rainmaker has crossed the Atlantic a couple of times and has done well in the SORC solo race series for the last couple of years too
Interesting blog, thanks !
Wouter Verhulst
10 Dec 2020
80% will be flat water cruising, so im searching for a boat which cruises with higher speed (but is stil ok in handling) So without backstays /mast rig is a pre. Really like what i've heard about the 395. And the interior is ok for family purpose (not to racy inside) So planning to continue buying one.
Wouter Verhulst
10 Dec 2020
I'm not sure which sail combination is recommended. I think 70% will be a 5 to 16 knots of breeze. So based on handling simplicity (not too much extra hands) , im not sure what to prefer with a furler system.
blush2
26 Dec 2008
Change the rig to fractional ? Blush is 3/4 fraction, the runners meet the mast at the same level as the forestay. The first reef is very deep and allows the head of the main to pass under the runners, so once reefed both backstays can be left on.
Wouter Verhulst
10 Dec 2020
Hi, almost in the end phase of buying a 395 and after survey, nothing big structural subjects to be found. Thats good. Very easy to manoevre, and around 7.5-7,8 SOG while motoring. It was a nice testing day.
They do have found some moisture points at the scepter poles and before the genua rail and some small points around the baby attachment before the mast.
I have some doubts about the brochure weight. It has been stated that total weight is about 5000 kg. On the internet i have found different numbers. One at 6700 kg. One 6200 kg. Yesterday 's weight during the survey was around 6900. Anyone who has some reference about a realistic weight range ? Thanks!
michael_w
8 Oct 2005
Try the RORC rating office. Someone is bound to have a 395 with an endorsed IRC rating which amongst other things involves the boat having its empty weight checked on a calibrated load cell.
Lightwave395
14 Aug 2016
My last endorsed IRC cert quotes the 'hull empty' weight at 6700kgs, but FWIW that is with my different keel, pictured here with the different mast step:
Wouter Verhulst
10 Dec 2020
Interesting. With this keel /diesel and water and whole interior is 7000 kg. Does that seem ok for you? Is that normaal/ good in your opinion? Thank you very much.
Lightwave395
14 Aug 2016
I would suspect so, I've not seen a keel design as you've pictured. My certificated weight is with the boat completely 'empty', no fuel, water, anchors, chains, or anything else. in fact preparing for an IRC weighing makes you realise how much junk you sail around with !
If you don't already have one this link will download the original Oyster brochure:
https://oysteryachts.com/assets/files/Oyster_395LW-Model_Brochure.pdf
Amandla Kulu, the boat I raced on is pictured at the top of this page and Rainmaker, referred to above is also featured:
Oyster Lightwave 395 | Oyster Yachts
Wouter Verhulst
10 Dec 2020
I see around 5 different keels with the oyster. This one seems to llookthe same. Why so many differences i wonder.
