Oxidised Zn anode
TiggerToo
23 Aug 2005
UK
I have an old anode I removed a while back. It is covered with a white salt, which I assume is Zn(OH)2.
Is it possible to remove this and continue using the anode? Should I do it chemically (how?) or by physical removal, e.g. with a wire brush?
Slowtack
27 Feb 2007
Not advisable to use a steel wire brush as it affects the electrochemical properties of the anode I believe... Sand paper should be OK.
NormanS
10 Nov 2008
Isn't it noticable how all the pear shaped anodes have a big lump of steel through them with tails with holes for fastening them to the boat. That doesn't seem to stop them from working.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
The iron is separate from the zinc. If the strap affected the action of the anode, attaching a zinc anode to a steel structure would be ineffective, which of course is nonsense. US military conducted considerable research into this, which no doubt you can look up. MIL specs limit Fe to very low levels.
NormanS
10 Nov 2008
What I don't understand is why cleaning an anode with an ordinary (steel) wire brush is apparently a no no.
That's not going to change the molecular structure of the zinc, any more than the adjacent steel strap.
Earnest searching after truth.
rogerthebodger
3 Nov 2001
Well, painting it is not going to work either!
There is no painting on my anode but my boat is well painted under the water with antifouling and epoxy below the the antifouling.
Yes paint will protect the steel from rusting but an anode will also protect the steel from galvanic corrosion and help where he painting does not completely cover the steel of the paint film gets damaged like the bottom of the keel
NormanS
10 Nov 2008
I think he's referring to the careless splodges of antifouling on the anode. I take mine off to clean them up, and don't replace them until the antifouling is done. Makes sense to me.
rogerthebodger
3 Nov 2001
Well Yes
That picture was some time ago when I washed down and antifouled between tides whit a maxim tide range of 2 meters
These days I pull my boat put on a 25 ton trolly and keep it there between spring tides so have much more time to remove the anodes and clean down better.
I also now get 2 local guys to wash and paint the hull with a full 20 liters of antifouling again wit note time to give better protection with 2 fill coats and an extra coat tital 3 and the water line and the keel and chine leading edges.
This lsts a fill 2 years with little fouling
