Oxalic Acid
Courageous
17 Aug 2003
Ireland and Spain
www.courageous.it
Hello chaps. Would anyone know where I might get hold of some Oxalic acid crystals to clean up the teak on me boat? Have tried local chemists but they are no longer allowed to supply in case I do a Norman Bates on me mum.....
ronniewood
3 Jun 2001
Clyde. Scotland
Look up your local Yellow Pages for Chemicals supplier - such as the type that supply school labs etc.. Only trouble is that you have to buy a 1/2 kilo or more at a time.
Was the only place I could get it, so have enough for a lifetime - but the results were worth the effort.
Ecartar
18 Dec 2001
Why not try NETROL available from Crown Decorator Shops. Easy to use, very effective. Designed to deep clean teak garden furniture. I've used once a season on teak laid decks with no ill effects to the boat or myself!
Regards,
As always 'do your own research'. The opinion expressed here is a personal one and is not to be taken as a definitive answer.
CharlotteRusse
17 Mar 2004
Burkshire
You can buy as much as you like mail order from Rydenor at the website below:
http://www.rydenor.co.uk/
on this page:
<A target="_blank" HREF=http://www.rydenor.co.uk/index.php?cPath=51&osCsid=c9f905f87f61c240c288a92346c03286>http://www.rydenor.co.uk/index.php?cPath=51&osCsid=c9f905f87f61c240c288a92346c03286</A> to be precise.
isandell
1 Mar 2003
You might find a local furniture restorer/repairer willing to sell you a small quantity and also advise on use and dilutions.
Ian
seahorse
30 May 2001
I've used "Patio Cleaner" from B&Q with good results on both wood & gel coat to remove growth/stains. Brush on, leave for a while then hose off. I think it's about £4 for 10L.
montezuma
6 Mar 2002
Southern UK
There's an oxalic acid based gel designed for cleaning gelcoat called Y10. It brings up tired gelcoat wonderfully, but it also cleans teak. Suspect it might be a more expensive option than crystals, though.
Joe_Cole
14 Feb 2002
FWIW I usually use two heaped table spoons of crystals in half a pint of water and it seems to work OK.
When I'm using it in wallpaper paste (I prefer it this way; it stays on the surface to do its work rather than just flowing away) I mix a very thick paste then add the crystals. The paste need to be thick as the crystals seem to thin it down.
Wonderful stuff. Wear rubber gloves, avoid splashes and paint it on to the surface.
Joe
smee
22 Feb 2002
Mallorca
A Book called Hull and Deck repair suggests AJAX scouring powder which is one tenth (approx) the price of Teak Deck cleaner containing oxalic acid. The only thing I don't know, is if AJAX scouring powder is still sold! If not in supermarkets, perhaps it is in older style hardware shops!
pugwash
30 May 2001
SW London
In the last few weeks i have bought three lots at three different chemist shops. Maybe you just have to shop around.
davidparker1
6 May 2004
You have been misled by your local chemist. Oxalic Acid is listed in the Poison Rules as a Part 1 poison and can therefore be supplied to a legitimate user known to a local pharmacy. The poisons register will require completion. He can obtain Oxalic Acid from J.M.Loveridge plc, Southampton and probably other sources.
Franklin
12 Jun 2001
Gibraltar
Always use a concentrated solution ie fill a bottle with hot water and add oxalic acid crystal until no more will dissolve. If you want a gel add wallpaper powder.
About its toxicity, so is antifouling etc etc Wear gloves and don't drink it.
AndrewB
7 Jun 2001
Dover/Corfu
Scouring powders like AJAX or VIM are not a good idea. The bleach in them won't work on rust, so to clean you have to scour the surface away. Not only hard work, but it will leave a matt surface that spoils GRP gloss and quickly attracts dirt. By comparison, oxalic acid effectively dissolves the rust, leaving the surface unaffected.
