LittleSister
I would like to fit a battery monitor - nothing fancy, just to keep track of battery charge/discharge. Money is tight. I have available such a monitor (Blue Sea, if I remember correctly - can't lay my hands on the documentation just now) and shunt. The shunt is rated at 200 amps.
Most of my loads are modest (a few lights, a few instruments, small fridge, small diesel blown air heater, small domestic water pump, etc.), but I've had a bow thruster fitted of 'nominal' current draw of 315A and recommended fuse of ANL 250, i.e. higher than the 200A rating of the shunt. (In a previous thread it was said that such motors have very high initial momentary current draw then it drops, but I don't know whether that is true or by how much it drops.)
1) If I put this in the monitored circuit will it fry the shunt, or fry or confuse the battery monitor?
2) If I run the bow thruster separately (i.e. bypassing the shunt), will this render the battery monitor readings completely meaningless most/all of the time, bearing in mind that I don't anticipate using the bow thruster often, and very rarely for more than a few seconds? (He said tempting fate!)
