Aquastar 33 Ocean Ranger
Hi, I have a twin engined Aquastar 33 with Perkins Sabre 225Ti engines. All the exhaust systems including the Vetus mufflers have been replaced. The port engine cools the exhaust & muffler perfectly & is 29 degrees at the sensor position. The starboard exhaust sensor alarms at 59 degrees & this happens when I am motoring up a river at 6 knots at 1100 revs. When running at 1400 to 1800 revs the alarm doesn't come on but still runs hotter than the port engine at about 50 degrees. I think I have eliminated any problem with the engine heat exchangers as both engines run at their normal temperatures. As a test I have also swopped over the raw water inlets to the exhaust elbows of each engine. This confirmed that the heat exchangers are working ok because the starboard exhaust still overheated. The overheating seems to be just around the exhaust sensor. I am wondering if the exhaust elbow outlet holes are sufficient because when swopped over the water outlet cooled the port exhaust perfectly. Any ideas?
