Squeaky
Good evening:
Would appreciate some input on a question of overheating engine.
My neighbour has been complaining that his engine which was completely overhauled 40 or 50 hours ago is overheating and we have been trying to locate the problem.
We have removed and checked the neoprene raw water impellor which was ok. Tomorrow he will attack the heat exchanger to ensure that all the tubes are clear.
We have attempted to check the temperature gauge by measuring the resistance of the sender when hot and then applying the same sized resister to the gauge and the reading check out leading us to believe the temperature gauge is ok.
I have thought that he seemed to throw a lot of water against the quay when supposedly running at 800 rpm on the tachometre - personally to me it sounds much faster than that as that is my rpm in "tick over".
This afternoon I ran mine (29 ft - 23 HP) at 2000 rpm in gear while he ran his (32 ft - 30 HP) at 800 in gear and compared the amount of water thrown against the pontoon. I think his was pushing about 50 % more then mine leading me to believe that his tachometre was not correct or the propellor was much too big.
I am of the opinion that one can cause an engine to overheat simply by running it too fast - for example trying to make it exceed the hull speed etc.
My neighbour claims his engine will overheat at 800 rpm which if correct clearly indicates a problem but what if the tachometre is not correct and it is actually reving much faster trying to move an immovable object.
Would this not cause it to overheat????
By the way his exhaust seems to throw out more water through the exhaust then mine when running much faster.
Comments welcome.
Cheers
Squeaky
Comments welcome.
Cheers
Squeaky
