PabloPicasso
O
What is that type of shackle called?
FWIW, here are some of the safety measures that are mandatory in the Classe Mini, the 6.50 m boats that are raced single-handed across the Atlantic.
The lifeline tether must be releasable from the chest end, while under load. For most people that means putting one of these on the chest end, so it can be released if you are getting dragged beside the boat.
There must be a means of getting back on board the boat from the water. For most people that means a piece of hollow webbing secured across the stern of the boat, from one quarter to the other. The webbing must be long enough that it can drop down 50-60 cm into the water so you can get a foot onto it. You then put some bungie cord inside and sew it into the webbing near the ends. This keeps the webbing out of the water when sailing, but when it is pulled down the bungie stretches and the webbing will come down. Depending on the height of the transom you might need a second "rung" of webbing as well, at a slightly higher level. You need to experiment a bit with the lengths of the webbing and bungie to get things right.
Another alternative is a line or webbing that goes a meter or so into the water, with loops for your feet every 30 cm or so. But the design needs to be such that stepping on a lower loop does not close the upper loops.
I also personally carried an EPIRB on my person at all times, although that is really only meaningful if you wear a life jacket to keep you afloat until help arrives.
If your budget runs to 10,000 EUR for electronics you can get an NKE autopilot with a remote control. The boat can be programmed to heave to and activate the MOB button if the base station on the boat loses contact with the remote control.
