Scubadoo
Hi All,
Just want some advice before I commit to the cost of having my DPE outdrive overhauled.
This year I discovered for the first time in 20 years the Outdrive oil to be milky. So decided it will need more than a normal service (oil change, bellows etc) i.e. seals replaced (prop shaft/selector), pressure test etc.
While it is in the workshop should I also get the cone & shoe replaced as the drive has done nearly 1000 hours. The Volvo dealer said they can't tell if it needs replacing by a visual inspection. I don't remember having any issues with the clutch/gear operation i.e. operating as normal. So undecided if I need to do this.
Also will have the UJ checked, steering bushes replaced, is there anything else I should consider.
With all the above being done, it will be quite expensive, so just trying to judge what needs to be done vs nice to have etc.
Thanks.
Thanks.
